Rear Worklight amperage TC29D
   / Rear Worklight amperage TC29D #1
Typhoon
Southern Illinois
LS MT357HC
Greetings! On my TC29D, there is a rear worklight connector/wiring. I know that when the key is turned on, this connector is energized. My question is, what kind of current will this particular circuit handle? I would like to have 3 55w lights on it, but I don't know the amperage capacity. Does anyone know?
Thanks..
   / Rear Worklight amperage TC29D #2
I would check with your dealer. Most setups on the JD's anyway are only rated for 2 55 watt lights, or about 8 amps.
   / Rear Worklight amperage TC29D #3
I put two lights on my roll bar and hooked them into the plug. The plug itself gets pretty hot after a while. Also when starting and using the glow plugs you have to have your lights off. If I have the tractor lights on and the two on the roll bar I will blow the main fuse.
I would wire, switch and protect from the battery.
murph
   / Rear Worklight amperage TC29D #4
3 lamps @ 55w .. thats 165w.. @12v.. yuo will be pulling just under 14a.
What size wire is it? If it's a larger gauge wire.. probably ok.. however.. the switch may not handle the extra rating. If it was me.. I'd put a 'fog lamp' relay in, and have the relay actuated by that line, and then wire myself a 10ga wire from the battery ( fused to 15a ).
Soundguy
   / Rear Worklight amperage TC29D #5
I believe on a TN those little plugs are 10 Amp. I suspect NH is consistent in the use of that plug's capacity.
Andy
   / Rear Worklight amperage TC29D #6
That answers the question then!
Soundguy
2007 Chevrolet Suburban Multipurpose Vehicle (MPV), VIN # 3GNFC16097G214917 (A57453)
2007 Chevrolet...
Club Car Electric Golf Cart (A57149)
Club Car Electric...
UNUSED 250 GALLON FUEL TANK (A58375)
UNUSED 250 GALLON...
Jisan Heavy Duty 66in Excavator Bucket (New/Unused) To fit 36 Ton (A59225)
Jisan Heavy Duty...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
1997 Dorsey 45' Aluminum Citrus Trailer (A57148)
1997 Dorsey 45'...
