Reasonably priced Top and Tilt?
   / Reasonably priced Top and Tilt? #1
jba3520
Eatonville, WA
JD 3520
Can anyone tell me where I can get a reasonably priced Top and Tilt cylinders with hoses for my Cat 1 3ph on JD 3520?
What is the purpose of the check valve on the cylinders from CCM? I have seen other cylinders and they don't seem to have them.
CCM also is out of stock and they don't know when they will get more. Is there anyone else that carries these? I really don't want to spend the $900.00 to the JD's.
   / Reasonably priced Top and Tilt? #5
jba3520,
The purpose of the check valves is to keep the cylinder in the desired position. It is to prevent/reduce leakdown somewhere in the circuit or if you blew a hose or valve.
There are lots of other places to get cylinders and make your own. Many guys on TBN do exactly that. You can go to Surplus Center for one and get the cylider and hoses etc. They even sell checkvalves if you want them, but the ones they have are very large compared to CCM.
Hope that helps.
   / Reasonably priced Top and Tilt? #6
Since CCM is out of stock your best bet is to search TBN and find out what others have done in your situation.
For the most part, you have to determine the cylinder stroke and retracted length that you will need. Then find a comparable cylinder from say Surplus Center. Then get the type of rod ends you need for your tractor, tie rod or ball. Then cut off the old ends and weld on the new. Total cost should be in the $400 price range or less. A local hydraulic repair shop would be a good place to start.
For this attachment, paying $500 extra for JD green paint is not a very good investment, in my opinion.
   / Reasonably priced Top and Tilt? #7
The ones I seen yesterday @ JD were your standard black.
Green color must be extra. :rolleyes:
   / Reasonably priced Top and Tilt? #8
Ha! CCM was out of stock and they were not sure when they would get more two years ago when I was buying mine! I sure liked the idea of their double check valves, but honestly had to wonder about parts etc. if one ever broke. I ended up biting the bullet and buying from my manufacturer. It doesn't have the check valves, and will leak down about 1/2" in a couple of hours, but at least it was in stock and when a fitting broke on the cylinder it was fixed that day. Nothing against CCM, but that is who everyone kept mentioning back then and nobody could get parts from them. I laugh because I know I've seen a dozen times where people have called them and they were "out of stock". It sure makes a guy wonder...
   / Reasonably priced Top and Tilt? #9
I just got a hydraulic top link and it's on the way from redlandhill on ebay. it was $149 + $7.50 for shipping. It included the eyes on the ends. Their phone no. is 1-910-652-0101.
Harris
   / Reasonably priced Top and Tilt? #10
Well I have to chime in here as I recently put a TNT on my rig and had a simlar experience with CCM. They were out of stock on the cylinders when I initially called and over an 8 month period I called at least 6 times and heard the same story, out of stock and it would be a couple of months. I had heard of, and read, the horror stories of the OEM Kubota TNT setups but after the 8 months I had waited, I decided to go for the OEM kit. I had spoken to my dealer and relayed my concerns and was assured that if there were any problems with the OEM system, they would take care of them.
I have now had the dealer installed OEM TNT kit for 6 months and my results may be out of the norm but I love my setup. As far as I can tell, it does not leak down and this is after 2-3 hours of box blade work and 4-5 hours of mowing.
I let the dealer install my set-up and while I probably ended up paying too much, I have been using my setup free from problems for 6 months now. Your mileage may certainly vary but I am completeky happy with my OEM TNT.
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
2014 Club Car Electric Utility Cart (A51691)
2014 Club Car...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
New/Unused AGT MX-MRT14 Mini Skid Steer Loader (A51573)
New/Unused AGT...
2016 Ford F-550 Ext. Cab Flatbed Truck (A52377)
2016 Ford F-550...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
