Rebuild shredder gear box
   / Rebuild shredder gear box #1
fredm
I am rebuilding a 90hp gear box on my mower.
The gasket was broken when I took it apart. Can I just not use it and use only RTV?
also the bottom cover seems to put tension on the bearings. How much torque should I put on these bolts?
   / Rebuild shredder gear box #2
You'll be a lot better off contacting the implement manufacturer with these questions.
However, I'd make a gasket before using RTV (which is good stuff but it's a bit of a pain to remove if you pull the gearbox off again).
As far as bolt torque...well, good qestion for the manufacturer. Otherwise, look up the torque for the thread size/pitch and grade of bolt and use standard torque values.
TORO TRX-20 WALK BEHIND TRENCHER (A51406)
TORO TRX-20 WALK...
2000 FORD F450XL SUPER DUTY SINGLE CAB FLATBED TRK (A51406)
2000 FORD F450XL...
1998 FREIGHTLINER CST120 TANDEM AXLE SLEEPER TRUCK (A56129)
1998 FREIGHTLINER...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2016 BOBCAT T595 SKID STEER (A52705)
2016 BOBCAT T595...
