Rebuilt Farmall Cub has Fire but won't start
   / Rebuilt Farmall Cub has Fire but won't start #11
yes the plugs getting gas the funny thing is it wont fire from eithier i wondewr is it the ethnol in the gass is my problem u know this tractors didnt have ethnol running in there days
As a mechanic you understand that the plugs should not be wet. If they are wet why would that be?
i know in the pass most of these cubs allways leaked a little out of the weep hole under the carb so thats not worrying me that bad but it shouldnt leak at all its a new carb actually its the second one the other one did the same i wish oi could have used the orginal one i rather rebuild them then buy a after market one
   / Rebuilt Farmall Cub has Fire but won't start #13
Older engines had very weak fire. This made them very easy to flood. Once the plugs get wet they don't have strong enough spark to fire thru it. Many times I've taken out the plugs and dried them. I've also unscrewed them, lay them over the hole with the plug wire on, turn engine over and let the plug ignite the fumes to dry out the compression chamber.
I would choke the carb as a last resort. Still sounds flooded.
im not much on typing my wife started this thread for me but im trying to get back to u guys one finger typing if that makes since
if there wet its not burnning the gas
you thinking its fouling the plugs
i agree with the flooding
   / Rebuilt Farmall Cub has Fire but won't start #18
Hoping cub ownere will see this and offer suggestions.
I would dry everything and start over. Trying to start it as lean as possible. Slowly adding fuel until it started or flooded.
If it floods without attempting to start then we'll look elsewhere for the problem.
Are the spark plugs new?
what do u think about the pantronix fireing where it fires faster
do away with the points
Mohawk 12,000lb Two-Post Electric Auto Lift (A54811)
Mohawk 12,000lb...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A51694)
2022 Polaris...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2016 BOBCAT S770 SKID STEER (A52705)
2016 BOBCAT S770...
1978 Taylor TY-250M Forklift (A53117)
1978 Taylor...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A54607)
2013 KENWORTH T680...
