reciprocating saw for cutting branches?
   / reciprocating saw for cutting branches? #12
Unless you'll have ready access to an outlet I'd go with a cordless, and then look at the brands that have a wide variety of tools that use that same battery as batteries for cordless tools generally aren't cheap.
Personally I use Makita 18v cordless tools as being able to use the same batteries for a reciprocating saw, a chainsaw, a powerhead that can attach a string trimmer (or pole saw), a leaf blower and all my other cordless tools to be extremely convenient. Plus they tend to run specials where buying a tool/battery combo-pack will include with an extra set of batteries.
If you do have ready access to an outlet then a corded Milwaukee saw can make some really quick work of tree limbs (especially when using an orbital cutting action).
In either case a pruning blade for reciprocating saws makes a difference over a blade meant for cutting lumber.
   / reciprocating saw for cutting branches? #13
Pole saws and chain saws are too much maintenance. Oil for the chain, constant tensioning, and sharpening. NO THANKS! I will save my chainsaw for logs and stuff it was made for.
A good ol battery powered reciprocal saw is hard to beat and you can use it for anything from steel to wood.
If you have a fat limb up high just tie it onto a pole and snap the battery in. I use a 16' piece of aluminum T-bar.
   / reciprocating saw for cutting branches? #14
Before the latest advancements in cordless tool batteries...several of the multi-attachment power head tools...string trimmer, edger, hedge trimmer etc., etc...also had reciprocating saw attachments...they have gone by the wayside with cordless pole chain saws...
   / reciprocating saw for cutting branches? #15
I don't think you would be please with reciprocating saw more so if you needed to reach above your head...pole saw or small chain.
I certainly agree with the pole saw suggestion. I do have a battery powered reciprocating saw, and have tried it for pruning. Yuck. A kitchen pairing knife would work better. The pole saw can be used for cutting limbs, probably up to 4" or more. And it is also good for clearing vines such as blackberry vines, honeysuckle, etc.. Having a pair set of nippers handy in your back pocket is always a good idea.
I'm not suggesting that the pole saw is a replacement for your regular duty chain saw, but it will quickly become the #2 tool in your possession.
Regarding the maintenance complaint - yep, pole saws, as well as every other tool does require maintenance. That simply part of the game.
   / reciprocating saw for cutting branches? #16
The 20v Black and Decker Alligator Lopper chainsaw is about as safe as you can make a chainsaw. I used one my son-in-law had and it worked fine for small limbs up to about 4 ". The chain is almost completely covered so not much chance of getting into it and it is around $100 which is about as cheap as you will find a battery powered chain saw. If you already have some 20v batteries, then $88 will get you the saw. Personally I prefer a pole saw, but that is because all my trimming is up high .
   / reciprocating saw for cutting branches? #17
I have two cordless reciprocating saws:
The small one is balanced for one hand operation, while holding the branch with the other hand:
I use the bigger one for larger branches and trees:
This cedar was 24' tall:
   / reciprocating saw for cutting branches? #18
The 'trick' to using a recip saw is to use it properly in the first place. Hold the shoe tight to the work-piece like it was designed. Too many users don't, and they complaining about vibration, bent blades, shaking object to be cut, etc. :rolleyes: (OEM shoe can be made longer or redesigned as needed for large diameter rounds.)
My neighbor has the B & D Alligator Lopper, corded version. Easiest, safest, and most ergonomic limb cutter I've ever seen, but a two-hander to use. I use a Echo 12" top-handle saw when in the man-lift bucket. It's a dandy one-hander, and I'd have the 18v cordless 10" Makita top-handle saw in a minute if I didn't have the Echo already. Cost isn't much different. :)
   / reciprocating saw for cutting branches? #19
I just used my Ridged 18 volt (sawsall) to cut off a dying bush at my Lady Friends place. Yes it worked, but compared to a chain saw, it was painfully slow. The orbital feature does help.
2008 JLG 800S MANLIFT (A58216)
2008 JLG 800S...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2005 Kobelco 135SR Hydraulic Excavator (A56857)
2005 Kobelco 135SR...
2020 TIKING GAS GO-CART (2) SEATER (A58375)
2020 TIKING GAS...
1998 Club Car Electric Cart (A56859)
1998 Club Car...
2011 Ford Crown Victoria Sedan (A54815)
2011 Ford Crown...
