Rat Rod Mac
- Joined
 - Oct 22, 2006
- Messages
 - 177
I'm putting my John Deere dozer back together after having to replace the hydraulic pump. The system has drained out so all of the fluid will have to be replace. No problem, probably should be done every once in awhile anyways. I was going to go to Tractor Supply and buy it, but looked on the inter-net and their hydraulic fluid is not recommended if it has to be used in an application with wet clutch plates. Seems there is an additive that attacks the glue that bonds the fiber plates to the steel plates. Would this TSC hydraulic fluid be ok for my application that just raises and lowers the blade? Is there a better fluid out there that I should/could use instead? Thanks for all answers and suggestions. Much appreciated.   RRM
