Recommendation for best CUT
   / Recommendation for best CUT #11
That's really the problem in that 25-45/50 HP range as an apples to apples comparison can become difficult given how widely the frame sizes/weight/capability can vary. For example: a B2650 is almost light enough to be within the rated lifting capacity of an L3560.
Granted I'm of the thought patter that identifying what needs to be done, and how long is acceptable to do the task is a major driver when looking at buying a tractor and then let that and the budget drive the tractor sizing decision.
For me personally at this point I don't think I'd go smaller in either HP or frame size/weight than my current L3560 for my 2.75-ish acres. Almost all of it needs to be finish-mowed (occasionally twice a week), and there are a couple dozen large trees (mostly in the yard) that shed some pretty significant limbs from time to time, then add in the 5,000sq ft. garden... Of course, I'm not sure I'd go that much larger either since the capability increase doesn't seem to cover the price difference for what I needed - or do.
Well, at least not until jumping into full-up utility tractors (which is something I may add at some point).
There's just a whole lot of variability in personal needs and tractor capability when it comes to that HP range -- so it almost ends up being the case there's not really "a best", so much as there's a "best for you"
Well right its all about comparing apples to apples. When I looked at the 2650 I also looked at the 3350,, numbers wise actually the 3350 isnt any better and had two dealers say not to buy it over the 2650. Now the L3560 is a lot different tractor but your also paying about 10k more for it. Like you said it depends. Lot of tractors that arent much different then there are some that are.
UNUSED LANDHERO LDH-GAC40Y AIR COMPRESSOR (A57193)
UNUSED LANDHERO...
UNUSED FUTURE SF60 60" HYD SIDE SHIFT FORKS (A57193)
UNUSED FUTURE SF60...
Industrias America L6 (A56469)
Industrias America...
UNUSED SDLANCH SDLGC80 GOLF CART W/ TOP (A57192)
UNUSED SDLANCH...
Deere 335P (A53317)
Deere 335P (A53317)
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
