Recommendations for Pole Barn builder in Michigan
   / Recommendations for Pole Barn builder in Michigan #12
I know here in NJ that cost per square foot is running around $10. Depends on many factors but in general $10 is a good number. No concrete or electric in that number though.
For the basic metal sided shell cost is about $7-$8 psf. Cost with some windows and doors, roof overhang, roof insulation can run you up to $9-$10psf.
Rich
   / Recommendations for Pole Barn builder in Michigan #13
Some cost a bit, some almost nothing. Note that the price of steel siding and also roofing, although common, are not cheap. I found that for about $200 dollars more I could have vinyl siding over OSB and for about the same, a shingled roof, again over OSB. The 8 foot over-hangs on both sides added about $1 to $2K total and the 12' soffits (eaves) somewhere around $500. Pictures follow:
   / Recommendations for Pole Barn builder in Michigan #14
Another pic of (somewhat cluttered) overhang. The builder originally proposed going straight in from the soffits to the side wall, but I'm really glad I decided against it. I now have room for tall objects, can get my tractor with the rollbar up in on each end, and I eliminated that "bird-winged" look I've seen that results when you don't follow the contour of underside up with the rafters.
   / Recommendations for Pole Barn builder in Michigan #15
Another pic. Used steel siding under overhang. Probably would just use vinyl if I had it to do over, but the builder felt the steel would save on labor and it seemed like a good idea at the time. With the current price of metals, would not be surprised that vinyl might now be cheaper too.
Bobcat Skid Steer Forks (A50322)
Bobcat Skid Steer...
2021 Ram 1500 Bighorn (A52748)
2021 Ram 1500...
New Bobcat 18" Bucket (A50774)
New Bobcat 18"...
2016 JLG 2646ES 26ft Scissor Lift (A50322)
2016 JLG 2646ES...
