Recommendations for the 4500 stump grinder
   / Recommendations for the 4500 stump grinder #11
JackIL pretty much has it. Mirror makes it easier. Grinder works OK around the house for stumps and bushes with lots of roots... You can grind a 2 foot stump, it takes a while. To do it occasionally would be OK. To do it everyday would take forever. If you want to grind stumps everyday, get a real stump grinder.
Last, unlike JackIL, I've never taken the mirror mounting brackets off the frame of the tractor. They don't seem it interfere with any attachment (I have a power bucket with a grapple, not a slip scoop)...
If you dont have a mirror, you need a spotter and a mirror is a lot easier. Last, not sure how you run it and NOT sit on the tractor, seat switch will turn front belt drive off.
When using it ....You do need to trim as much off the stump as you can with a chainsaw first. You move forward and start cutting, not really deep, but turn the steering wheel side to side to make the cut wider. I usually set the handbrake when turning the wheel.. If you bite in too much, the belt slips and just lift the grinder a bit....
Pretty useful, I do a lot of stumps for the neighbors. Don't charge anything, but always seem to get something back.
   / Recommendations for the 4500 stump grinder #12
Sitting on the machine looking at a mirror to see past the chips is half *** at best. That isn't one of Ventracs better ideas, chips flying towards the mirror to see what your doing for depth and length of cut. It is a total joke....... It does work good standing by the machine and actually seeing what you are doing...... jim
   / Recommendations for the 4500 stump grinder #13
The chips are expelled toward the tractor at ground level. The mirror is in front of the grinder, so no chips are flying toward the mirror.
   / Recommendations for the 4500 stump grinder #14
On a Ventrac stump grinder I rented was new and the chips go forward ..... jim
   / Recommendations for the 4500 stump grinder #15
Also there is very little room to the rear for anything, it is very tight and nothing goes to the rear for those little mud flaps sealing the back off. I wish you could reverse it like the one on a Powertrac when you get a root jammed in it........ jim
   / Recommendations for the 4500 stump grinder #17
jackIL is correct ... chips come out the back. Must be something wrong somewhere....
   / Recommendations for the 4500 stump grinder #18
Yes look at the video , all the chips are in the front.......comming out over the stumping you try to see trough that with a stupid mirror ? how can you gage depth? ..... jim
   / Recommendations for the 4500 stump grinder #20
Yes it does turn that way but the back of it is sealed off and chips go forward because they have nowhere to go. That is why they jam up on roots so easy, they can't get away. They need more room to get away like on the Steiner model...... jim
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2002 International 9200i Truck (A55218)
2002 International...
CAT CHALLENGER 65B (A53843)
CAT CHALLENGER 65B...
2017 Nissan Frontier Ext. Cab Pickup Truck (A54814)
2017 Nissan...
2015 JOHN DEERE 250G LC EXCAVATOR (A52705)
2015 JOHN DEERE...
1996 Timpte 46ft Hopper (A55301)
1996 Timpte 46ft...
