Sigarms
Super Member
Depending on electric rates of course, first thought would be a 14 SEER R410 heat pump system with a 80% variable speed two stage LP furnace. Heat pump would run say till it's 35 degrees outside for heat (with R410A you get a higher discharge temperature), gets REALLY cold outside, you then have your lp furnace for back up heat (again, need to look at the cost comparison between LP and electric if this is "worthwhile").
With a ranch and the sq footage, do you have a basement (equipment location)?
Think about wrapping your duct, not lining it.
May also want to think about zoning.
Can't beat hydronic heat, only issue is you still have to bring in the A/C (if you need it) and costs more money.
Honestly, in our area, that quote you got for GeoThermal isn't bad.
davemhughes, look at a continuous hot water heater, may be worth your time.
