Recommendations on trailer for hauling TYM 554 with Tacoma
   / Recommendations on trailer for hauling TYM 554 with Tacoma #11
Third generation Tacomas have a 3500 lb tow rating. You're asking to haul a 5500 pound tractor plus at least a 2000 lb trailer which at 7500lbs is more than double your manufacturer listed tow rating. If it's a temporary transportation need you'll need to look into renting if it's continuous you'll need to upgrade to a bigger truck.
   / Recommendations on trailer for hauling TYM 554 with Tacoma #12
I had a tacoma v6 with towing package and needed to move 4000 tractor 2 miles around the corner. I used a 7k trailer, I only did it once as the truck and trailer was not the right equipment. upgraded to a 2500 and 14k gooseneck trailer now is the perfect setup for my longer moves.
2mi around the corner saying you average 15mph you could drive it in less than 10min.
   / Recommendations on trailer for hauling TYM 554 with Tacoma #13
If you're hauling it from your driveway on flat surface streets at 25 or less for a couple miles? Probably. Anything else? No way in hell I'd do that. It is grossly over the capacity of that truck.
   / Recommendations on trailer for hauling TYM 554 with Tacoma #14
Heck, for a couple of miles around the corner, I'd just drive the tractor on the road. I regularly drive my tractor 5.5 miles between two properties here. But then I live on the outskirts of a small village in a rural area. Seeing tractors on the road is quite normal here.
   / Recommendations on trailer for hauling TYM 554 with Tacoma #15
1/2 ton truck and 10k trailer minimum as others have pointed out...
I'm assuming it's further than 2miles others are mentioning here
Freightliner Tender Truck - Adams Tender (A56436)
Freightliner...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A56858)
2013 Chevrolet...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
2012 FORD F-250 SUPER DUTY (A58214)
2012 FORD F-250...
2004 DITCH WITCH 3700 RIDE ON TRENCHER (A52709)
2004 DITCH WITCH...
