Dargo
Super Member
- Joined
- Mar 6, 2004
- Messages
- 5,981
- Location
- S. IN
- Tractor
- Jinma, Foton, TYM, Belarus, Yanmar, Branson, Montana, Mahindra and maybe some green and orange too.
Well, what do you think the outcome will be? I used Red Line 10W-30 oil in my 2001 Chevrolet Suburban 5.3 liter V8 285hp, Amsoil SAE 5W-30 in my 2001 Town Car Cartier with a 4.6 liter V8 240hp, and Mobil 1 in my 1996 Dodge Ram 3500 4X4 with a 5.9 liter Cummins diesel 392hp (modified - last hp on dyno in 2004).
Initial observations were that the Amsoil and Mobil 1 seemed normal, but the Red Line was a pain in the rear to wipe up when spilled! It seemed to really cling to everything. Be careful when pulling your funnel out and dripping Red Line on your engine. I keep my engines very clean, and I had to actually use a detergent solution to get it off of my engine. Dry rags and paper towels would not seem to get it off. Does this mean anything? I don't know.
I intend to do an oil analysis on each vehicle as soon as they reach 5000 miles with the oil. Previously, each vehicle received an oil and filter change at almost precisely 3000 miles with regular dino oil and the factory filter. On the Dodge, I stayed with the Cummins Fleet Guard oil filter, the Lincoln got the Motorcraft filter, and the Chevrolet got the AC Delco oil filter. I stayed with the same filter on each. Other than the Cummins being modified, the other engines are completely stock and have had all manufacturer recommended maintenance performed at the suggested intervals. None of the engines have had any sort of failure or have had to be repaired.
I'm not sure what lab I'll use, and am open to suggestions. I plan to use the same lab for each to try to get a standard type of result and the exact same tests. As far as the oil goes, I used the Mobil 1 in the Cummins because it takes 12 quarts and the Mobil 1 was the least expensive. The Red Line was by far the most expensive at just at $8 per quart. The Amsoil came in at about $1 a quart more than the Mobil 1.
Each vehicle gets a mix of highway and in town driving. However, the Lincoln in general will have more highway miles on it, and the Suburban will generally have the most in town miles put on it. I guess that about covers it. Anyone have any other suggestions to monitor or note to make the comparison fair?
