Redirecting startup exhaust
   / Redirecting startup exhaust #11
For the 34 years I worked as an auto mechanic, virtually all the shops I worked in had the standard exhaust hoses and the aluminum fixture in the garage door to stick it outside. Has been awhile since I had my shop but the last time I bought these items the fixture for the door was about $16 - has a swinging flap to keep the hole covered when not in use. An 11' section of the 4" hose was about $50 but it is totally heat proof and collapse proof - you can drive all over them, even on gravel and not hurt it and they last virtually forever. You can also get adapters to couple lengths together and a "Y" connector to use on dual exhaust or for 2 vehicles. A word of caution - whatever you use will get very hot after just a little while, especially if you idle it up for more than 10 minutes or so, chose your material wisely.
   / Redirecting startup exhaust #12
Has any one made a extension, for the pipe on a L3410, so it keeps the black off the sides and the loader arm
   / Redirecting startup exhaust #13
I do that with my 1910 because it smokes pretty bad. I got rubber exhaust hose, about 10 feet, at an auto parts store. I let it run at 1200 RPM for 10 minutes and the hose is not very hot. Diesels don't get too hot idleing. I don't think I'd use plastic hose though.
2022 31 MINI SKID GRAPPLE BUCKET (A55745)
2022 31 MINI SKID...
VERMEER 605F ROUND HAY BALER (A51247)
VERMEER 605F ROUND...
2008 Chrysler Town and Country (A55758)
2008 Chrysler Town...
2019 MACK ANTHEM AN64T  TANDEM AXLE SLEEPER (A56138)
2019 MACK ANTHEM...
2014 CATERPILLAR 826G LANDFILL COMPACTOR (A51406)
2014 CATERPILLAR...
2025 GIYI VR66 66in Vibratory Roller Skid Steer Attachment (A53421)
2025 GIYI VR66...
