logan97
water on the floor. Took off the back panel and cleaned the freezer drain ( black hose ) today there is ice on the bottom of the freezer once again. any suggestions ?
not a clue about your problem. just asking to ask
does fridge have a ice maker or cold water dispenser?
is fridge area correct temp? is freezer correct temp?
is the fan inside freezer part working?
is there a fan between freezer and fridge?
if you get back into the drain were the coils are in the freezer.... can you pour water down the drain... and have it come out in the "pan" located at the very bottom of the fridge?
no ice maker or dispenser.
yes correct temp
fan working ?
water came into the drain when I cleaned the hose.
I'm not quite understanding your issue. But, if you are saying that the freezer is icing up. It sounds like it isn't going into defrost or, the defrost heaters aren't working.....
