reinstalling tire on rim
   / reinstalling tire on rim #11
Another tool that works well for tire irons, which wasn't designed for that purpose, is a nail bar. There are even miniatures that do well for smaller tires bikes and cycles. Common brands are Estwing, Stanley and at one time Vaughn made the best in my opinion. The 90° end makes a decent handle and the opposite end has about the correct angle of off set. I knock the sharp corners off a little with a file and polish it up just a bit.
   / reinstalling tire on rim #12
Another tool that works well for tire irons, which wasn't designed for that purpose, is a nail bar. There are even miniatures that do well for smaller tires bikes and cycles. Common brands are Estwing, Stanley and at one time Vaughn made the best in my opinion. The 90ー end makes a decent handle and the opposite end has about the correct angle of off set. I knock the sharp corners off a little with a file and polish it up just a bit.
Sounds like you're talking about the Wonder Bar and of course you're right. Mine has been handy for lots of things.
   / reinstalling tire on rim #13
i've seen a rim shot 60' in the air doing the gas and match trick.. left a smoking tire too.. :)
soundguy
   / reinstalling tire on rim #14
i would change the tire on the tractor. it really is easier.i used to hammer the bead off with a ken tool wedge but now i use a bead cheata.2 crowbars and a big screw driver will work.i use a ken tool t45ac with a crowbar and big screw driver to dismount tires.i have found that caseih ether works good to set beads.
   / reinstalling tire on rim #15
soundguy
I think that is why you do it on the truck.
   / reinstalling tire on rim #16
hmm.. lighting a fuel fire under my truck / near my fuel tank.. uh.. NO there are proper tools to re-bead a tire.. I don't need to arson/immolate my good truck...
soundguy
   / reinstalling tire on rim #17
I was watching tv one time and these icelandic mechanics were changing a tire on a toyota truck. They were out on the arctic ice, on their way to the north pole, and needed a way to seat the tire on the rim. they had it on the rim, but it still needed to be seated.What they did was take a bottle of butane used for refilling lighters, and sprayed quite a bit in the tire. Next they tossed a match at it, and all the butane ignited, and the explosion seated the tire on the rim. Now this will only work on a tube less tire, and is an easy way to get hurt, but will work in a pinch.
I was having a heck of a time getting my bead to seat on my large rear R4 even using a ratchet and web strap to get it almost seated and soapy water to get it to seal, so after about 3 hours of trying, I tried the above mentioned trick using some starting fluid sprayed in the tire and then a stand off torch approach using a lighther and the starter fluid as a flame thrower. The whole thing took seconds and was no drama at all. There was no noise or flame from the tire. It just sort of popped all the way onto the rim. Man, was that great. I'll have no issue doing this again. :cool:
   / reinstalling tire on rim #18
bead cheetah tool is good too...
Electric Horseless Carriage (A57453)
Electric Horseless...
Quick Attach Pallet Forks (A57453)
Quick Attach...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
Toro Timecutter Max (A57453)
Toro Timecutter...
Metal Goat Family (A57454)
Metal Goat Family...
Predator 2000 Inverter/Generator (A57454)
Predator 2000...
