Relative value of each Deere Series
   / Relative value of each Deere Series #21
The tires were turf... they didn't know if they are were loaded...I don't want to get into a debate about tires, tire chains, R4s/R1s in snow, etc, but how do turf tires on a 4wd tractor do on snow and ice? My garden tractor with turfs and weights did not good on my sloped driveway until I got chains... And even with chains, I have to be careful... I'd be mighty embarrassed if a new 4wd tractor had to be towed up the driveway!
The turfs on my JD 870 4 wd did a good job on snow with no chains. I wasn't able to plow up the drive but never got it stuck in snow. With chains on it would have been that much better.
   / Relative value of each Deere Series #22
4runner,
I think you'll find that any L&G tractor vs a MFWD (4wd) CUT is not a fair comparison. MFWD (and you absolutely want this for FEL work) will really put a smile on your face. Plus, all of the CUT's you're considering should have rear diff lock. That'll give you 3 driving wheels when engaged. So I wouldn't worry about that
One more thing to consider. I was thinking that for most of your uses a 755 might be adequate but it only has 15 PTO hp. For instance if you'll mow in thick, wet grass or might want to add a rotary cutter or tiller later I'd go with something with more HP. I never used the PTO's on my 755 as I used it for landscaping stuff (rake, BB, loader), but some folks find the 755's to be a little under-powered.
Good luck in your search.
2004 JOHN DEERE 310SG EXTENDAHOE BACKHOE (A53843)
2004 JOHN DEERE...
ROLLER DOLLY (A53843)
New Holland 1412 Discbine Pull Type Mower Conditioner / Windrower (A55218)
New Holland 1412...
2018 CATERPILLAR 950GC WHEEL LOADER (A52705)
2018 CATERPILLAR...
2009 VOLVO VNM DAY CAB (A54607)
2009 VOLVO VNM DAY...
2019 Dodge Journey Crossroad SUV (A53424)
2019 Dodge Journey...
