Relief valve bypassing on new cylinder???
   / Relief valve bypassing on new cylinder??? #1
Kays Supply
Southern Illinois
Iseki TA 207
I just put an aftermaket grapple on my machine. If I bottom it out, in or out, it opens the relief valve. The arm cylinders don't do that. If you close or extent the boom it just stops. It doesn't unload the relief. Is there a way to add something to keep the new cylinder from doing this?
   / Relief valve bypassing on new cylinder??? #2
I do not understand how the other cylinders do not send the system into relief at the end of there stroke:confused: Regardless, It is not a problem for your grapple cylinder to do this...that is what the relief valve is for.
   / Relief valve bypassing on new cylinder??? #3
I just thought of something...You are using the AUX circuit for your grapple, and it probably has a separate PRV than the rest of the functions so it just sounds different I bet. No harm.;)
Thanks for the help, I just wanted to check before I did any damage. What experience I have had with hydraulics has shown me it can do a world of damage quick if not done right.
Water Pump (A54865)
Water Pump (A54865)
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
2015 Ford Transit 250 Cargo Van (A55852)
2015 Ford Transit...
2014 FREIGHTLINER CASCADIA (A55745)
2014 FREIGHTLINER...
2019 FREIGHTLINER M2 106 REFRIGERATED TRUCK (A52706)
2019 FREIGHTLINER...
