Remember to put anti-freeze in your pressure washer
   / Remember to put anti-freeze in your pressure washer #12
It's the high pressure pump on the pressure washer...it's the part that gets winterized. CAT is a brand name like Comet or General which are the 3 quality brand name pumps out there. And CAT water pumps are not made by Caterpillar...they are two different companies.
   / Remember to put anti-freeze in your pressure washer #13
Instead of messing around with antifreeze, why not use a air compressor and blow all water out ? i have a connector adapter i made to connect to my camper with and i winterize it. doing it to pressure washer should be fine too.
   / Remember to put anti-freeze in your pressure washer #14
Thanks for the reminder, I put WW fluid in the pump today.
Ken
   / Remember to put anti-freeze in your pressure washer #15
First of all these pumps do like to be run dry. Plus it's better to store them with liquid rather than air for corrosion reasons and to prevent the seals from going bad. Doing the air method is good way to diminish the life of your high pressure pump.
Check the manufacturer recommendations for these pumps and they will all say that when winterizing or if you won't be using the pressure washer for more than a couple of months, to preserve/winterize the pump with the appropriate fluid...not air.
Using air to winterize an RV domestic water system is fine because it's just a bunch of pipes, a low pressure pump (about 40psi) and maybe a hot water heater. A high pressure pump is very different animal.
2013 Jeep Patriot SUV (A50324)
2013 Jeep Patriot...
2007 Ford F350 Super Duty (A50514)
2007 Ford F350...
Unused 2025 CFG QK16R Mini Excavator (A50322)
Unused 2025 CFG...
SCAN FOR HAULING AND FINANCING INFORMATION (A51242)
SCAN FOR HAULING...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
2013 Toyota Prius Hatchback (A50324)
2013 Toyota Prius...
