Remotes coupler help
/ Remotes coupler help #11
The ones with collars (at least the ones I have gotten at TSC can be used as the breakaway style.
It takes:
Double Breakaway Clamp: Pioneer Double Breakaway Clamp - 1824481 | Tractor Supply Company
2 double acting sleeve quick couplers: Pioneer Quick Coupling, 1/2 in. Double Acting Sleeve Set - 1824407 | Tractor Supply Company
The sleeve part of the couplers goes into the clamp and is locked in place so that the inside moves (not the outside sleeve).
Aaron Z
So in essence you have a sleeved set of quick connects that are designed to be break away connectors used as a collarless set as long as you are using all of the correct stuff. :cool: While this is great, :thumbsup: aren't you really buying a collarless set up that can be used as a std setup? After All the setup doesn't allow you to use any std type sleeved QD in their special clamp. All semantics I suppose. ;)
/ Remotes coupler help #12
LOL. I was mounting them as remotes on the baler (to allow me to use the cylinder from the plow to aim the kicker on the baler) so I wanted them to act as breakaway connectors. Being as they were only a couple of bucks more for this type, it seemed like a good idea.
Aaron Z
INTERNATIONAL 454 TRACTOR (A62130)
INTERNATIONAL 454...
MULTIQUIP LIGHT TOWER (A60736)
MULTIQUIP LIGHT...
2000 CATERPILLAR 988F WHEEL LOADER (A62129)
2000 CATERPILLAR...
TANK MANIFOLD (A58214)
2023 John Deere Z994R (A60463)
2023 John Deere...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
