removal of inj pump
   / removal of inj pump #1
tmar04
YM 276
I'm removing inj pump for cleaning. it is the type that has its own oil reservoir(two small dipsticks) made by Bosch/Kiki, I think, and my tractor is a 2 cyl, 27 hp (and I hate to say this, because everyone says I am not correct) YM 276. I know I am correct because it is stamped in the clutch housing, on engine tag, etc. I have remove all securing nuts(4) but pump seeems to be hung up and won't come free. Surely I don't have to dissassemble the front of the timing cover, remove hyd pump, and all that. Any suggestions.
   / removal of inj pump #2
I just replaced my injector pump on my chinese tractor, and yes I had to remove the the inspection cover off of the timing case. There is a gear on the inside of the case that is attached to the injector pump with 3 mounting bolts, after removing the bolts there is one nut that attaches the gear to the pump with a keyway pin, if you remove the nut the pump will come out. Make sure you mark the position of gear and pump to help on reassembly. Good Luck
Galvanized steel fence (A53424)
Galvanized steel...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2013 WESTERN STAR  4900 (A53843)
2013 WESTERN STAR...
2014 FORD F-350 (A53843)
2014 FORD F-350...
2024 John Deere 872GP Articulated Motor Grader with GPS Package (A52377)
2024 John Deere...
