Removing 3pt hitch arms on a BX
   / Removing 3pt hitch arms on a BX #11
:thumbsup: you are welcome!
I second that...thanks guys (radioman and Golfaddict)......maybe I'll just call you collectivley, "radioaddict"..hahahahahaha
   / Removing 3pt hitch arms on a BX #13
Along with the PT hitch questions, is there an easy way to hook up the 3pt hitch to the implement? I have a new brush hog that I've hooked up to the 3pt hitch twice now and it is a real pain to get it hooked up. Is the best way to have all the bars in place on the tractor then spread the bars over the implement pins? Getting those arms on the implement pins is very difficult, you have to move the very heavy brush hog around quite a bit to get the pins to line up with the bar bushings. I was hoping that there was an easier process that I'm not coming up with.
   / Removing 3pt hitch arms on a BX #14
yup there is a easier way. get a quick hitch. Back up to hog - raise 3 pt, hook on then move levers to lock in implement. Hook up the pto and off you go.
   / Removing 3pt hitch arms on a BX #15
Happy to be able to help! :)
2005 Peterbilt 387 with Wet Kit (A56435)
2005 Peterbilt 387...
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
2007 Hummer H3 4X4 SUV (A56859)
2007 Hummer H3 4X4...
1454 (A57192)
1454 (A57192)
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2012 Big Tex 25ft. 9 Ton T/A Gooseneck Flatbed Equipment Trailer (A55973)
2012 Big Tex 25ft...
