Removing a Bush
   / Removing a Bush #11
Pull straight up as possible. If your tractor has enough weight, it should pop out with fel Or you can also run a chain over a big rim and pull off drawbar. Some weight in bucket will help. I'd attack perimeter roots with fel first in either case.
   / Removing a Bush #12
Most of the time I drag the bush out, but I have used the FEL if the bush is located in an area where I have trouble getting to with the back of the tractor. If the bush is real stubborn I lower the FEL and will dig to China to get it out. ( an anger management problem I have)
I have a log chain that has a 3 inch round loop on one end and I thread the log chain around the bush, through the loop, hook the chain to my clevis on my draw bar, and slowly pull the bush out. As the chain tightens around the bush, it rarely slides off. I have never pulled Lilac so do not know the root pattern but I have done this to some very hardy bushes and it has worked well for me. I have a John Deere 2010 and it is around 45 horse power so they come out quite easily. Any thing I want to keep I dig by hand, trying my best to limit any plant damage, load it into my FEL and move it to where I want to transplant it.
   / Removing a Bush #13
I agree with the pull it out method. Just wrap a chain around it and hook it to the drawbar. It leaves the least amount of cleanup to do. I pulled out 5 Lilac last year. None put up much of a fight.
Horse Weathervane (A55758)
Horse Weathervane...
Step Ladder (A47477)
Ford 7600 (A53314)
Ford 7600 (A53314)
2018 John Deere 470G LC Hydraulic Excavator (A53421)
2018 John Deere...
2025 78in Rock Bucket Skid Steer Attachment (A53421)
2025 78in Rock...
John Deere 6120E (A50323)
John Deere 6120E...
