Removing A Engine From a Bobcat 873
   / Removing A Engine From a Bobcat 873 #1
dnkndrick
Houston
873 Bobcat
I have to remove my engine from my Bobcat 873 to replace a couple of hydrolic lines and replace the diesel tank as it is leaking.
Can anyone tell me the process I have to got through?
Thanks in advance.
Dale
   / Removing A Engine From a Bobcat 873 #2
Thanks in advance.
Dale
Have you lifted the cab?
   / Removing A Engine From a Bobcat 873 #3
The engine and pump assembly are made to come out as 1 unit. There are 4 bolts with rubber isolation bushings holding it to the frame. Remove the muffler all lines, hoses, control linkages, and the 4 bolts then lift out as an assembly.
Thanks for the help. I'm assuming I have to take the cab off to do this?
   / Removing A Engine From a Bobcat 873 #5
You don't have to remove cab, just unblot the 2 front bolts and tilt it up out of the way to get to hose, linkange and front mounts.
First raise the lift arms up and place the Orange Lift arm stop over the lift cylinder, then lift the cab back. For added saftey so cab can't fall down, run a chain or ratchet strap from front of the cab back to the cross tube of the lift arm and secure it.
OK I'm at a sticking point. I have everything loose except one of the four bolts that holds the engine to the frame. It is the front one on the right side as your facing the engine. it is at an angle and it is very hard to get to. Is their a special tool I need to gt it out?
Again thanks for all the help.
   / Removing A Engine From a Bobcat 873 #7
No special tool. Some are able to get it with a crows foot, others have taken the hydraulic resevoir loose and moved it out of the way or take it out.
2011 SHOP MANIFOLD TRAILER (A58214)
2011 SHOP MANIFOLD...
2016 Toro Workman GTX Utility Cart (A56857)
2016 Toro Workman...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A56129)
PEMBERTON...
2017 Polaris 500 Ranger Diesel Utility Cart (A55787)
2017 Polaris 500...
SHOPBUILT SINGLE AXLE MOTORCYCLE TRAILER (A58374)
SHOPBUILT SINGLE...
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
Looks like your ad blocker is on.
We rely on ads to keep creating quality content for you to enjoy for free.
Please support our site by disabling your ad blocker.
Continue without supporting us
Choose your Ad Blocker
  • Adblock Plus
  • Adblock
  • Adguard
  • Ad Remover
  • Brave
  • Ghostery
  • uBlock Origin
  • uBlock
  • UltraBlock
  • Other
  1. In the extension bar, click the AdBlock Plus icon
  2. Click the large blue toggle for this website
  3. Click refresh
  1. In the extension bar, click the AdBlock icon
  2. Under "Pause on this site" click "Always"
  1. In the extension bar, click on the Adguard icon
  2. Click on the large green toggle for this website
  1. In the extension bar, click on the Ad Remover icon
  2. Click "Disable on This Website"
  1. In the extension bar, click on the orange lion icon
  2. Click the toggle on the top right, shifting from "Up" to "Down"
  1. In the extension bar, click on the Ghostery icon
  2. Click the "Anti-Tracking" shield so it says "Off"
  3. Click the "Ad-Blocking" stop sign so it says "Off"
  4. Refresh the page
  1. In the extension bar, click on the uBlock Origin icon
  2. Click on the big, blue power button
  3. Refresh the page
  1. In the extension bar, click on the uBlock icon
  3. Refresh the page
  1. In the extension bar, click on the UltraBlock icon
  2. Check the "Disable UltraBlock" checkbox
  1. Please disable your Ad Blocker
  2. Disable any DNS blocking tools such as AdGuardDNS or NextDNS
If the prompt is still appearing, please disable any tools or services you are using that block internet ads (e.g. DNS Servers).
