Removing a Radiator
   / Removing a Radiator #11
If it's a steam boiler, there shouldn't be any water or not enough to worry about. If it's a water boiler ,the radiator should be full of water. Most boilers have some type of valve on the line above the floor.The ones that I have worked on are old & the valves won't seal all the way off when closed, that's why I say to be carefull because you could get burned if the unit isn't shut down & the valve doesn't close off all the way.
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A54815)
2022 McConnel...
2017 HINO 268 BOX TRUCK (A54607)
2017 HINO 268 BOX...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
2011 Ford E-350 Passenger Van (A53422)
2011 Ford E-350...
22ft Rollback Flatbed Body with Winch (A51692)
22ft Rollback...
Unused Delta Crash...
