Removing driveway culvert
   / Removing driveway culvert #11
Township wants to charge me $600 to do this job thats why I was thinking of doing it myself. If I have to buy new culvert and have fill brought in it might not be that much cheaper then what the township wants. What do yall think?
Now that we know more; I'm inclined to pay the township $600 to do it, and if they screw-up, it's their responsibility to fix it.
The township board member really wants me to abandon my whole drain pipe project and hire one of his employees (on the side) to come out and put in a 300' swale for $1500 right next to my $1200 (just for material) failed drain tile job.
And how much is the board member's employee going to kick back to the board member for this side job? That part sounds fishy to me.
   / Removing driveway culvert #12
Hello All!
I just happen to notice your posts concerning your gravel driveways and replacing culverts.
I don't have a gravel driveway myself but just so happen to be working on an episode for Disaster House (airs on DIY network), "Gravel Driveway Disasters".
The premise of the show is we recreate accidental or natural home disasters to a house that was slated for demolition. We then bring in construction experts who show our viewers how to prevent or fix said damage.
Im in search of a real life GRAVEL DISASTER STORY that was visually documented (photo or video) with the homeowner willing to share the story.
It can be random, funny, awesome, or just plan disastrous!!!!
Thanks!!!!
Julie
   / Removing driveway culvert #13
I believe the first thing I would do, is see if you have enough fall to drain the water. Do you know anyone that have a level, or transit..?? A simple Lock Level, and folding rule, or tape measure will do the job. You'll need to see how far beyond the culvert you'll need to go, to let it to drain properly. 2% of fall is sufficient.
If it's a smooth bore pipe, they can be moved. You can straddle the pipe, clean off the top within an inch or so, then offset yourself enough to dig down past halfway of the pipe. You need to relieve the side presure at the widest point. It may take some handwork to get it fairly clean. When totally exposed, put chain around an end, and gently lift. If it is the bell type connection, it should pull apart, lifting up. Just be careful of the rubber gasket. When reassembling, use some spray on vegetable cooking spray as a lubricant. Take the hoe, and push back together gently. Use a solid object to buck against. Tree, post, etc.
Digging beside it, and letting it roll in lets material on the lower side fall in the hole, and not have a level bottom of the ditch. Twice as much work, trying to clean it up, with the pipe on top of it.
Also, remember you will be shooting grade for the invert (flow line) of the pipe, not the O.D. With a 16" pipe, I'm guessing 1 1/2" to 2" walls of the pipe, so you will need to go that much deeper where the pipe will lay.
Just guessing here, but where you live, I'm betting thye specified 67D, or 304 Limstone over the pipe. Should be fine for reusing, although if the pipe was just put in th ditch, then covered, you may get a lot of dirt mixed in with the clean limestone backfill. As mentioned be sure to tamp it back in in lifts. You'll have an extra wide hole to allow a plate tamper alongside the pipe.
Under highways, we put sand around the pipe, and covered about 1'. Then flooded them with LOTS of water. You'll get approx. 98% compaction when the water soaks out. then you can cover with limestone, and compact. Doubt they let you do that though... They wouldn't let me do that, just south of you in the next neighboring county....
All in all, if you don't have your own hoe, renting a steel plate, and other costs incurred, $600.00 isn't all that bad, by the time you figure it all up. And in the big picture, if it doesn't drain properly, it's the Townships baby...
   / Removing driveway culvert #14
Hello All!
Julie
Julie,
Silver Creek NY had several ponds blow out over the last couple of years due to high rains, I would do some research on that.
   / Removing driveway culvert #15
I think I'd give them $600 before they change their mind.
That is some sound advice, I charge $375 just to bring a compact on site, $750 for an excavator and $500 for the backhoe.
   / Removing driveway culvert #16
i see this is a post from 2010...jobs probly been done...
plastic culvert can be lifted out, once you dig along side and remove the fill on top...
i use a length of 4"/6" I-beam as a spreader bar...4 slings spaced evenly over 20'
if you have a foot or so of mud in the bottom, it can be a problem...sometimes you can get the local vol. fire dept. to hose it out for a donation...
2005 EZ-GO Cart (A55853)
2005 EZ-GO Cart...
4 Cubic Yard Dumpster (A55851)
4 Cubic Yard...
2006 International 4300 Altec TA50 50ft Material Handling Bucket Truck (A56858)
2006 International...
HOMEMADE 6' X 16' DOUBLE AXLE UTILITY TRAILER (A57192)
HOMEMADE 6' X 16'...
DIRT DOG CLR60 60" RAKE (A57192)
DIRT DOG CLR60 60"...
2023 Caliber Trailers GH840MST 40ft 6 Ton T/A Gooseneck Flatbed Equipment Trailer (A55852)
2023 Caliber...
