Removing FEL 4520 - Video??
   / Removing FEL 4520 - Video?? #11
I have'nt removed mine yet, but I saw via removal/reinstalling by the previous owner how important it is to have it on level ground (preferably concrete) before removing. It took about 10 minutes versus what he said should not be over a 2 minute task. I'm sure someday I'll have a reason to remove it. If not for use, the major service would be a little easier with it off and out of the way.
It's a 2 minute job once you've done it a few times...that first time or three is the learning curve, so don't knock yourself for taking more then a few minutes. I can't remeber how long it took me the first time...but it was a h3ll of a lot longer then a few minutes.
It also takes one or two passes to get the tractor lined up with the loader.
Level ground is important though.
Jimmydee
Does anyone have a video or know of a place where I can get one that shows how to remove/reattach a FEL on a 4520.
The manual will be a bigger help then a video. Just read it and go step by step. This isn't a race to see how quick you can do it. Just do it by the manual and safely...you'll get faster as you get more experience.
   / Removing FEL 4520 - Video?? #12
A couple of points:
I find it is more stable if the bucket has some load in it. Also the 400CX is a little bit trickier as you have to curl the bucket at the same time as the masts come up.
2009 NISSAN Murano AWD SUV (A55758)
2009 NISSAN Murano...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A55302)
2023 Kubota...
2019 TEREX PHOENIX 2100 TROMMEL SCREEN (A54607)
2019 TEREX PHOENIX...
Adams 6T Fertilizer Spreader (A55301)
Adams 6T...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATE (A54757)
UNUSED LANDHONOR...
