Removing floor tiles is HARD WORK!
   / Removing floor tiles is HARD WORK! #11
Many old tile and adhesives have asbestos as a ingredient. You may want to test your tile and adhesive
   / Removing floor tiles is HARD WORK! #12
I've seen tile removed with a heat gun to soften glue. Tile peels right off.
   / Removing floor tiles is HARD WORK! #14
Reads like an excuse to buy an SDS-Max hammerdrill.
I've got the Harbor Freight unit and have to admit, it's actually pretty nice. Makes quick work of punching through 10" concrete walls when drilling holes, and with a pointed jackhammer bit on it breaks up concrete very well.
Voted: would buy again.
   / Removing floor tiles is HARD WORK! #15
I bought a used palmer floor striper, off ebay for $100, and have done a number of floors, for me and my extended family, sure beats a hammer chisel or putty knife, the tayler unit is nearly the same machine.
what would take a day or two with a hammer and chisel can usually be done in 30 to 45 mins, or less,
(my DD spent two days in there old bathroom with a hammer and chisel, and I did her kitchen about 4 times the size, in about 30 mins),
well worth it to rent or even to buy if you have a lot to do, IMO
I have seen an attachment for saws all, kind of a large putty knife attachment,
reciprocating saw scraper, - Google Search
   / Removing floor tiles is HARD WORK! #17
ok -- first off -- from personal experience -- stay away from reciprocating saws with scraper blades attachment. it has too much movement for my liking and when it does strike - sometimes it works sometimes it just jars you right back. you have to use a right balance of angle, speed, and watch what you are doing . no too dangerous.
i have used the harbor freight mini jack hammer with flat blade -- it works, but its also tedious. i used bosch sds bulldog -- it doesnt have the movement like the harbofrieght one but its lighter, smoother and softer. still tedious. those OLLLD tiles on concrete are a BEAR. you cant heat them up and then pull since concrete would suck up so much heat like heatsink it just a waste of gas. if it was on wood subfloor. if it was the newer tiles yeah comes right up with some heat.
whatever you do -- its breathing protection time since it must be one of those old tile before 80s and they use nasty stuff. IF you got a weekend of free time and you can rent a floor scraper, you can stand up ad abuse the heck out of it since its old tiles on concrete. otherwise you will be on your knees all day using a hammer drill type with flat blade. done it several ways and -- my vote is ... rent. :2cents:
   / Removing floor tiles is HARD WORK! #18
If that vct is down that good, you should consider going over it. Most flooring adhesives, and thinsets will now adhere to vct.
   / Removing floor tiles is HARD WORK! #19
Rent an electric floor tile remover.
+1. When they did my remove and replace they used one of them. Piece of cake. Operator didn't even break a sweat.
   / Removing floor tiles is HARD WORK! #20
Linoleum over plywood I do in two stages. Big heat gun to remove most of it then wallpaper steamer to remove remaining backing paper and glue. Easy to do.
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
2010 KMC 3376 Peanut Combine (A56438)
2010 KMC 3376...
2021 KOMATSU WA200-8 WHEEL LOADER (A60429)
2021 KOMATSU...
159120 (A60430)
159120 (A60430)
2018 CATERPILLAR 313FL GC EXCAVATOR (A60429)
2018 CATERPILLAR...
Miller Big 40 Portable DC Arc Welder Generator (A55973)
Miller Big 40...
