3-Point Hitch Removing plastic shroud on PTO shaft
   / Removing plastic shroud on PTO shaft #1
dustinfox
New Hampshire
Kioti CK35 HST
Just got done digging a bunch of holes with my auger and the end of the PTO shaft that connects to the auger got mucked up with sand and dirt. I would like to clean up the knuckle joint and grease it but it would be much easier if I could remove the safety shroud. It looks like it should come off but not sure. Anyone know how and if this thing comes off?
Thanks!
   / Removing plastic shroud on PTO shaft #2
On the end of the shroud there will be most likely 3 rectangular shaped heads with slots across them. Take a common screw driver turn the heads 90 degrees and the end shroud should just slide right off. Good Luck.
Great! Thank You!
Wow... That was sooooo easy! Thanks again!
2021 Hyundai Elantra SEL Sedan (A50324)
2021 Hyundai...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
2014 Ford F-150 Pickup Truck, VIN # 1FTFW1CT4EKG42947 (A51572)
2014 Ford F-150...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A52576)
2014 INTERNATIONAL...
2001 Fontaine 35' Detach Trailer (A50121)
2001 Fontaine 35'...
John Deere 4020 (A50120)
John Deere 4020...
