3-Point Hitch Removing plastic shroud on PTO shaft
   / Removing plastic shroud on PTO shaft #1
dustinfox
New Hampshire
Kioti CK35 HST
Just got done digging a bunch of holes with my auger and the end of the PTO shaft that connects to the auger got mucked up with sand and dirt. I would like to clean up the knuckle joint and grease it but it would be much easier if I could remove the safety shroud. It looks like it should come off but not sure. Anyone know how and if this thing comes off?
Thanks!
   / Removing plastic shroud on PTO shaft #2
On the end of the shroud there will be most likely 3 rectangular shaped heads with slots across them. Take a common screw driver turn the heads 90 degrees and the end shroud should just slide right off. Good Luck.
Great! Thank You!
Wow... That was sooooo easy! Thanks again!
1988 Ford Ranger Pick Up (A55272)
1988 Ford Ranger...
Cargo Van (A59230)
Cargo Van (A59230)
Breaker Box (A57454)
1997 Peterbilt 378 Tri-Axle Heavy Haul Truck, VIN # 1XPFD69X4VN428289 (A57453)
1997 Peterbilt 378...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(1) HD 20ft Free Standing Corral Panel (A57453)
(1) HD 20ft Free...
