Removing Quaking Aspen
   / Removing Quaking Aspen #11
Aspen is soft enough you can chew them quickly with a stump grinder. How many stumps are we talking here?
Maybe a weekend's rental of a skidsteer and a stump grinder would get you to where you could brush hog it?
   / Removing Quaking Aspen #12
If its like here the density is very high, thousands per acre. Not really stump grinding territory. If you doze out the stumps you could bushhog it for a few years and the trees will stop coming up for a while.
   / Removing Quaking Aspen #13
I would walk over the area and count the stumps. As you are counting the stumps, use red marking spray paint to mark stumps. Them contact someone with a track hoe and dozer. Obtain a price for using the track hoe to extract the stumps and then use the dozer to pile them up. Stump extraction with a dozer can get expensive in a hurry.
   / Removing Quaking Aspen #14
Taking out Aspen stumps with a root raked larger dozer is one of the faster ways to go. Following up with that big heavy disc is just icing on the cake.:)
   / Removing Quaking Aspen #15
I looked at the rental sheet for the larger Caterpillar dealer in our area and a D4 is only 1400 a week. You might choke on that number a bit, but think of how much work you could get done with that machine in 40 hours.
   / Removing Quaking Aspen #16
Something here is strange. The Alder or Quaking Aspen in our area sound exactly like those in Michigan & Canada except. Here the trees rot so fast that they aren't good for fire wood and both the tree and stump with be completely rotted and gone within a year of falling. When I clear a thicket of Quaking Aspen I don't even consider chipping the trees because next year both stump & tree are "fluff".
They are soft wood trees, but even a few years after cutting they are still pretty substantial. Certainly not something that a small compact tractor would be able to cut off/extract easily with a loader. I do think that if a large dozer could cut them off flush with the ground, then after a few more years of sitting and possibly being run over with a disc they would rot to soil.
Year: 2017 Make: Chevrolet Model: Sonic Vehicle Type: Passenger Car Mileage: 105,385 Plate: Body (A55853)
Year: 2017 Make...
UNUSED SDLANCH SDLGC ELECTRIC GOLFCART (A54756)
UNUSED SDLANCH...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
UNUSED JCT HYD AUGER (A54757)
UNUSED JCT HYD...
2012 Chevrolet Impala Sedan (A55853)
2012 Chevrolet...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55787)
2025 Kivel 48in...
