Removing Water From Diesel Tank
   / Removing Water From Diesel Tank #11
Just set the drum in a nice sunny spot. Solar will dry it in no time and for free. By all means filter before use.
Just had a Northern Tool open near me. Goldenrod water filter is available in a spin on and cartridge element.
Is one better than the other? Only a few dollars price difference in the element so $$ are not a issue. Both have positive reviews.
Which one is the best??
   / Removing Water From Diesel Tank #13
This is the easy and simple way.
I got most of the water with a cloth on a piece of PVC pipe and set a small fan over one bung and it dried up what little water was left in there.
Northern Tool just opened a new store up the road and the Goldenrod spin on and cartridge water filters are available.
Which is the best? Both are only about $10 difference in price.
   / Removing Water From Diesel Tank #15
If you get the cartridge one, be sure to get the filter wrench. I broke the housing on my first one. A new housing cost more than the entire filter assembly so I replaced the whole thing. Then I found one of my local stores started stocking the Golden a Rod filter wrench which fits the lugs at the top of the clear housing. No problem after that of course.
   / Removing Water From Diesel Tank #16
I have been a fan of using this cheap little funnel. Great for when you are pouring from small fuel containers. A regular fuel filter on a pump is ideal for larger fuels supplies, but this thing is great for smaller applications.
Mr. Funnel
Home
   / Removing Water From Diesel Tank #17
There are different models. Some only filter "dirt", other models filter water and "dirt". Here is information on the "water block" model:
"WATER-BLOCK spin-on canister absorbs water from gasoline and diesel fuel, and filters microscopic particles (10 microns) of rust, sand, dirt, scale and lint. Restricts fuel flow as water is absorbed, signaling the need for a canister change. "
Note, the water block ability is disabled with gasoline containing ethanol.
It's also disabled if you treat your fuel with additives which contain a water dispersant ... like the white Power Service ... ;)
   / Removing Water From Diesel Tank #18
Before you fill with fuel you can give it a rinse with 90% alcohol.
90cummins
   / Removing Water From Diesel Tank #19
90cummins
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
2020 VANGUARD CIMC 53FT REEFER TRAILER (A54607)
2020 VANGUARD CIMC...
2020 Brenner 450 Gallon Skid Mounted Vacuum Tank (A52377)
2020 Brenner 450...
2017 Chevrolet Tahoe SUV (A52377)
2017 Chevrolet...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
