Remvoing Lower 3-point Hitch Arms on the BX
   / Remvoing Lower 3-point Hitch Arms on the BX #1
Samwise
North San Juan
Kubota BX2370
How do you do it? Nothing in the manual. I see how to take the cover plate off that the side to side adjusters attach to. But that just uncovers the pin the two lower arms pivot on. And it seems that axle / pin is trapped between the frame on each side. Am I missing something?
Thanks in advance.
   / Remvoing Lower 3-point Hitch Arms on the BX #2
Once the center plate is off you can slide the arms toward the center. The ends of the pin sit in removable bushings. Pull those toward the middle and you can tip the big pin out of the oversize holes in the frame.
Z.
   / Remvoing Lower 3-point Hitch Arms on the BX #3
AND the BX is WAY easier vs my old B2920 which had a solid shaft all the way across. To remove you had to twist/pull/cuss the shaft to the left to remove the right arm, then twist/pull/cuss the shaft to the right to remove the left arm. And no you could not get a hammer between the shaft and the tire. I ended up having to use a giant Philips screwdriver through the pin hole, twisting/pulling back and forth. It would be an understatement to say that I hated its guts! lol
Got the linkage off - just as you said. easy peasy. Thanks for the quick response.
2007 Ford F-450 Chip Dump Truck, VIN # 1FDXF47P97EB35140 (A57453)
2007 Ford F-450...
2010 INGERSOLL RAND  G25 GENERATOR (A58216)
2010 INGERSOLL...
BUNDLE OF 6" X 12" BUILDING PURLIN (A54757)
BUNDLE OF 6" X 12"...
Sakai SV540T Padfoot Compact Roller (A57453)
Sakai SV540T...
2006 CATERPILLAR 304C (A58214)
2006 CATERPILLAR...
UNUSED CHERY INDUSTRIAL 20' BI-PARTING IRON GATE (A58376)
UNUSED CHERY...
