Ford tractor
Platinum Member
- Joined
- Apr 7, 2010
- Messages
- 973
Point 1 -- get the insurance. You may very well find some old metal objects that could do damage. Most equipment rental places have insurance against all damage for a fairly reasonable $$, especially cheap if you hit something and pop a hole in the tire, or break the deck.
Point 2 - have the rental place show you how to use the machine. JD's are real simple. Typically just set the rpm, set the deck height, then stop and steer like a car. You will have to know where the PTO control is and the deck height control. Rest your hand on them so you can raise the deck or shut off the pto should you hit a rock, stump, engine block, etc.
Point 3 - wear hearing protection!
Go slow and try to run a route where your first pass throws the grass out. A spiral moving counter clockwise is probably what you will do. The second pass will be hours later and the cut grass will be dry and easier to re-cut. The second cut you can go back and forth, or a different pattern so you get all the areas. If the grass is wet (as seen by moisture on the front tires), you may have to shut down, jump off and use a stick to clear out the wadded up grass in the deck.
NEVER use your hand, unless you want to only be able to count to 5.
Cutting for 8 hours and you will probably be using 1.5 gal / hour (maybe as high as 2) -- so have plenty of fuel on hand. No sense wasting rental time fetching fuel!
