Repairing Pipe Crimped On End
   / Repairing Pipe Crimped On End #1
drgill
Northen Virginia
Kubota 2320
I would like to repair (make round) a tube that has a partial crimp on the end. I can't just buy a new tube. Is there a tool that will make the end of a tube round again?
Thanks,
Dennis
   / Repairing Pipe Crimped On End #2
Sounds like a tough one.
Copper tubing?
Need a flare fitting on it, or what?
Tubing size is what?
Hydraulic high pressure, or low pressure water line?
Room to splice?
Need more info. :)
   / Repairing Pipe Crimped On End #3
They make tools to do that to thin wall exhaust pipe.
   / Repairing Pipe Crimped On End #4
Is this more complicated than it sounds? If you can find something an outside diameter the same as the inside diameter of the tube and has a tapered end, you can insert the item into the tube and gently bend it back into the proper shape. On small tubes a punch or similar is easy to use. For larger pipes you will have to improvise.
   / Repairing Pipe Crimped On End #5
Use a crescent wrench, fit it to the exterior diameter of the good pipe and work towards the end in a circular motion.
E/S
Wacker RT Walk behind Trench Compactor (A44391)
Wacker RT Walk...
2012 INTERNATIONAL 8600 TANDEM AXLE DAY CAB (A43004)
2012 INTERNATIONAL...
1998 Volvo VN Truck, VIN # 4VA7BBJF2WN759933 (A44391)
1998 Volvo VN...
6Yd Dumpster (A44571)
Toro Z Master 5000 60in Zero Turn Mower (A44572)
Toro Z Master 5000...
70in Dual Cylinder Grapple Bucket Skid Steer Attachment (A44571)
70in Dual Cylinder...
