Repairing Pipe Crimped On End
   / Repairing Pipe Crimped On End #1
drgill
Northen Virginia
Kubota 2320
I would like to repair (make round) a tube that has a partial crimp on the end. I can't just buy a new tube. Is there a tool that will make the end of a tube round again?
Thanks,
Dennis
   / Repairing Pipe Crimped On End #2
Sounds like a tough one.
Copper tubing?
Need a flare fitting on it, or what?
Tubing size is what?
Hydraulic high pressure, or low pressure water line?
Room to splice?
Need more info. :)
   / Repairing Pipe Crimped On End #3
They make tools to do that to thin wall exhaust pipe.
   / Repairing Pipe Crimped On End #4
Is this more complicated than it sounds? If you can find something an outside diameter the same as the inside diameter of the tube and has a tapered end, you can insert the item into the tube and gently bend it back into the proper shape. On small tubes a punch or similar is easy to use. For larger pipes you will have to improvise.
   / Repairing Pipe Crimped On End #5
Use a crescent wrench, fit it to the exterior diameter of the good pipe and work towards the end in a circular motion.
E/S
2005 Hino 268 Truck, VIN # JHBNE8JTX51S10984 (A44391)
2005 Hino 268...
2012 Craftsman YT3000 42in Ride-On Mower (A44572)
2012 Craftsman...
2012 Ford F-350 Knapheide Enclosed Service Truck (A44571)
2012 Ford F-350...
2016 W.W.Trailer All Around Aluminum Trailer (A45336)
2016 W.W.Trailer...
Scag Z Cat (A44501)
Scag Z Cat (A44501)
2014 Ford F-450 Liftmoore 5000W Mechanics Crane Truck (A44571)
2014 Ford F-450...
