Repairing sway arm bracket on 3pt hitch arm
   / Repairing sway arm bracket on 3pt hitch arm #1
KWRB
Bronze Member
Mexico, NY
Deere 4610
This weekend, the bracket broke off the 3 pt arm to which the sway arm mounts. Is there anything special about welding to the 3 pt hitch arm that I should consider before rewelding the bracket back on?
Are the list arms forged?
   / Repairing sway arm bracket on 3pt hitch arm #2
Usually the brackets are riveted or bolted on. Guess not this time?? As to welding on the lift arm. A professional welder could probably do it successfully by knowing the temperament of the iron he is working with. For me it would be a guess. Problem would be the welding could make the arm brittle and cause it to break. Can you post a pic??
   / Repairing sway arm bracket on 3pt hitch arm #3
You'll have to determine exactly what thew arm is made of for optimum results.
   / Repairing sway arm bracket on 3pt hitch arm #4
It's not rocket surgery. Whether the arm is forged or hot/cold rolled, you can weld a bracket to it. The question is whether you can weld. :cool:
   / Repairing sway arm bracket on 3pt hitch arm #5
True that!!! But still, have you ever saw a sway bracket that's welded to the lift arm???
2021 Honda Foretrax Rancher (A51573)
2021 Honda...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
FAKE (A52472)
FAKE (A52472)
(2) 330 GALLON POLY TOTE (A51248)
(2) 330 GALLON...
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
2019 JOHN DEERE 8245R LOT IDENTIFIER 174 (A53084)
2019 JOHN DEERE...
