Repairing sway arm bracket on 3pt hitch arm
   / Repairing sway arm bracket on 3pt hitch arm #1
KWRB
Mexico, NY
Deere 4610
This weekend, the bracket broke off the 3 pt arm to which the sway arm mounts. Is there anything special about welding to the 3 pt hitch arm that I should consider before rewelding the bracket back on?
Are the list arms forged?
   / Repairing sway arm bracket on 3pt hitch arm #2
Usually the brackets are riveted or bolted on. Guess not this time?? As to welding on the lift arm. A professional welder could probably do it successfully by knowing the temperament of the iron he is working with. For me it would be a guess. Problem would be the welding could make the arm brittle and cause it to break. Can you post a pic??
   / Repairing sway arm bracket on 3pt hitch arm #3
You'll have to determine exactly what thew arm is made of for optimum results.
   / Repairing sway arm bracket on 3pt hitch arm #4
It's not rocket surgery. Whether the arm is forged or hot/cold rolled, you can weld a bracket to it. The question is whether you can weld. :cool:
   / Repairing sway arm bracket on 3pt hitch arm #5
True that!!! But still, have you ever saw a sway bracket that's welded to the lift arm???
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A53421)
2017 JLG Skytrak...
Toro Workman HDX-D Utility Cart (A53421)
Toro Workman HDX-D...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A55851)
2019 Caterpillar...
Kubota SVL95-2 High Flow Cab Skid Steer (A55302)
Kubota SVL95-2...
DOOSAN G25KW GENERATOR (A53843)
DOOSAN G25KW...
Giyi Pallet Forks (A53314)
Giyi Pallet Forks...
