Suburban Plowboy
Veteran Member
I started a thread about a 60" mower deck for a 430 garden tractor, and I got off on a tangent worthy of a new thread. My deck's parts diagram calls for M63810 bearings on the blade shafts. I looked these things up. They're shielded, which means grease can get in, but dirt can't. When you look for replacement bearings, you are likely to find sealed bearings. These will keep grease out as well as dirt. You can't grease them using zerks. You have to replace them when they fail.
There is no way for me to know when the bearings on my used deck were changed last or whether they've been greased regularly. At the moment, I don't even know whether they're shielded or sealed. The original bearings were shielded, but the current ones may not be.
I don't want to have problems in the future, and bearings are cheap, so I'm thinking of replacing all 6 bearings instead of waiting for an expensive failure. What's the best course? Shielded or sealed? If I go with sealed, can I completely abandon greasing? I assume the bearings are the only things in the deck that need grease.
It would be nice to forget about greasing these.
