Replaced fuel filter on MF 263 now it won't start.
   / Replaced fuel filter on MF 263 now it won't start. #11
For future reference, the bleed screw on the inj pump is next to the name plate..double screw.. 5/16 head into a 7/16 body.
Loosen the 5/16 and crank the engine until solid fuel is seen with no air and tighten.
   / Replaced fuel filter on MF 263 now it won't start. #12
The Newer Perkins to me with electric shut off self bleed thru inj pump. The lift pump does have a screen in it some are in the top if it has a single screw others are on intake line pull line then take out fitting small screen there.
If there is no shut off someone took it out they came with a shut off and a plastic screen on them.
The reason you have to turn it over a little it is on a cam so if on high side
Is already pushed all the way.
There is also a screen on the in of the injection pump. Also I turn the key on. when pump gets soft usually will start.
AEROQUIP PROOF TESTER (A53843)
AEROQUIP PROOF...
MAHINDRA 2810 TRACTOR (A54756)
MAHINDRA 2810...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2019 TEREX PHOENIX 2100 TROMMEL SCREEN (A54607)
2019 TEREX PHOENIX...
2019 Allmand Bros Maxi-Lite II Towable Light Tower (A52377)
2019 Allmand Bros...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
