Kid,
the 9mm sounds about right, I went to a farm and home in town and the nut I used to start trying to find the size on the probe nut was a 10-1.50mm.
The nut for the probe is a 1/8-18NPT is what I'm thinking, a bushing I have that the probe fits is a 3/8-18NPT so if the standard increases by 8ths this would make sense ?? just not 100% at this point. I have many fittings (bushings) some with the size stamped on them which makes it somewhat easier to determine size of course the ones that don't have any stamping don't help with sizes but come in handy.
My tractor does have an oil temp guage it works, keeping fingers crossed till I get this issue ironed out.
I did a little more research and found the AGCO part number for the guage had changed twice before being discontinued, based on serial # 655 tractors after mine had the first replacement. Also the original was a water temp and ammeter combined. I just saw a thermo housing on Ebay with the elbow and thermo and it looked the same as mine as far as I could tell but couldn't really tell if the temp port was same size or not.
What year is your "Old M F" (I like that by the way) I would almost bet money the housings are the same but with the years maybe they were tapped differently, thats the only thing that would make sense to me.
My plan at this point is to remove the housing and see just what is going on inside that hole. If it's just a matter of drilling out the bottom and inserting the probe with no length problem it's good if not at least I'll have the housing off and be able to approach it differently.
As far as the altenator, it seems to charge during use not sure about idle the battery stays charged (very little ammeter movement, normal with no load).
It does have 3 wires so I'm guessing it has the internal regulator, the old "external" regulator is still on the tractor but nothing is connected to it.
Don't know much more about it, it works as far as I know so not worried about it for now.
I think my key switch might have a short or lose connection some where internaly, It's "I" "I-L" and "L" never used to start in the "I" alone before but now it will from time to time, I did remove the switch so I could access the throttle rod assembly a few weeks back and did tighten the connections so maybe it just some thing as simple as that IDK.
I think these other issues might be better off in another thread seeing as I've opened this can of worms.
Like I said before this tractor is easy to work on it just needs a little stroken from time to time.
Thanx again for all your feedback, much appreciated.
Mike
