Replacement Wheel
   / Replacement Wheel #11
This is my first trip around wheel fixing folks. If I have one with a rusted-out area around the valve stem (front 20 x 8 turf)...is it possible to just weld that area up and drill a new valve-stem hole?
Is it that simple?
Yes, it is that simple. When antique tractor guys do this they usually weld up the old hole completely then drill a new hole in a different location. You can grind the weld smooth the the repair will be difficult to find.
   / Replacement Wheel #12
Sure beats the heck out of $200 for a new rim.
I had a rice-patty Kubota a few years back and both front rims were pretty rusted-out in the valve-stem area. I had new tires and took them to a tire dealer, who told me I had to have new rims. One of his workers came over and whispered to me that he knew a guy that could fix them, but I went and bought new rims anyway. I should have listened to that guy I guess and I would have a few hundred more dollars in my pocket.
   / Replacement Wheel #13
dismount, weld and remount.. off road only though..
soundguy
   / Replacement Wheel #14
Now that I have my head removed from my butt and know I can fix them....I am going to run mine until I have to. I have one front that is rusted out a little but the others are okay.
These old tires are not totally gone, so I think I will get a little more mileage out of them and then put some new ones on with the wheel-fix....if I last that long. Or...at least wait until I have a flat.
   / Replacement Wheel #15
I'd fix them sooner than later.. the rusty metal will rip the tubes.
you can weld a washer in there once you grind all the rust out.. good place for a valve stem hole..
soundguy
   / Replacement Wheel #16
Washer....now that is another very good idea!
I am still fooling around with the steering box, but I don't want us to bring that into this thread. Been waiting on a part for two weeks....suppose to be here this week and then I can worry about tires after I make it go in the direction I am aiming.
Thanks for the washer idea.
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
SEPERATOR (A53843)
SEPERATOR (A53843)
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
2019 HYUNDAI VC2530152-JS DRY VAN TRAILER (A54607)
2019 HYUNDAI...
2022 Isuzu NPR 20FT Box Truck (A51692)
2022 Isuzu NPR...
