Replacement window sash recommendations
   / Replacement window sash recommendations #11
I've used both the Marvin Tilt-Paks and the Pella replacement units, and I highly recommend the Pellas. The Marvin setup uses track/balances separate from the sash halves, so the squareness of your opening is a factor. Pella is a complete 'box' that is designed to be adjusted to fit unsquare openings. Remove the existing window stops and sash halves, install and caulk the 'box' into the opening, and reinstall the stops. Very slick. Just be sure to have the Pella rep measure for you -- they deduct a certain amount from the opening size to ensure a correct fit.
7033 (A51691)
7033 (A51691)
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A55218)
2-Row Peanut...
2014 FREIGHTLINER M2106 BUCKET TRUCK (A51406)
2014 FREIGHTLINER...
(APPROX. 15) UNUSED IRANCH GROUND PROTECTION MATS (A54757)
(APPROX. 15)...
