Replacing a disk
/ Replacing a disk #1
merrickvilleguy
I cracked a disk on my #25 and have a spare laying around ... curious what the easiest way to get it out of there ?
I was initially thinking to just take the bolt off the axle give it a couple taps so its past the broken disk, replace the disk and put it all back. This has however given me a bit of trouble in that the nut is on there good and strong and cant seem to keep the assembly from spinning when give it a pull.
So will I be stuck taking hte entire assembly off the pillars and cranking on it that way or am I missing something simple ?
/ Replacing a disk #2
If you have a square axle, you could put a pipe wrench on one of the spools to keep in from turning while you back off the nut. Heat always helps break the nut loose along with something like WD 40 or Fluid Film. A Impact wrench will also work without spinning the whole gang. Ken Sweet
/ Replacing a disk #3
Are you sure you are loosening the nut and not tightening, one side might be reverse threads. I believe the left side (as facing it) is reverse cuts on our old disk, We had a heck of a time turning it, till the washer underneath finally cracked and split we realized we were turning it the wrong way....... amazing how tight you can get things with a breaker bar ain't it?
/ Replacing a disk
Ya on the gang im working on I can see the threads and am working with them to pop it off, even with the impact wrench this bloody thing is not moving. And by hand I can't stop it from turning ... I tried a propane torch on the nut but I don't think it got hot enough to make a difference ... so I soaked it with penetrating oil and will give it some time and another go in an hour or so
/ Replacing a disk #5
You got to usually get the nut red before it gives. Ken Sweet
/ Replacing a disk
Pics attached
A bit of time and more wd-40 and it came right off ... turned out my air tool wasn't up to the task so I "had" to add an electric one to my collection ha
The axle is a 1" x 0.9" rectangle, the hole on the disks however is 1" square. The disks are around 15 1/2" wide give or take. Will replace them next year as they will be fine for the current season.
/ Replacing a disk #7
Ken what is fluid film, never heard of that, and I am an old timer. lol zman:confused2:
/ Replacing a disk #9
Another good penetrant is Kroil, it makes WD 40 look like water. Kinda like a Turbocharged Fluid Film on steroids.
2022 EZ-GO ELITE...
2014 Freightliner 105' Bucket Truck (A63689)
2014 Freightliner...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
Great Dane Van Trailer 1989 (A63689)
Great Dane Van...
(2) UNUSED 380/85R30 TIRES W/ 10 LUG RIMS (A64280)
(2) UNUSED...
2021 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2021 Chevrolet...
