Replacing a hydraulic cylinder
   / Replacing a hydraulic cylinder #1
Kolas
Kubota B3200HSD
I bought a replacement for the hydraulic cylinder that raises and lowers the snow thrower mounted on the front of my Kubota B3200. The cylinder has no fluid in it and the hydraulic lines from my tractor are only partially filled (fluid leaked when I removed the lines from the failed cylinder. My question: How do I go about placing fluid in the new cylinder and its two hoses and get rid of any air in the assembly? There is no purge valve on the cylinder and there is no obvious way to fill the cylinder except by pouring new fluid into the cylinder fittings before attaching the two hoses. Any recommendations?!
Thanks,
   / Replacing a hydraulic cylinder #2
Just hook up the cylinder and cycle a couple times and it's good to go. Check the fluid on the tractor after, to make sure it's still on level.
Hydraulics are self bleeding. You just connect the lines and run it to push the air out and it's it takes.
   / Replacing a hydraulic cylinder #3
Yup, as @ptsg wrote, hook it up and operate it-the air will purge.
Thank you kennyd and ptsg!!
2012 Dodge Journey SUV (A55758)
2012 Dodge Journey...
2014 Bomag BW900-S50 (A47477)
2014 Bomag...
BL331A-80 Air Compressor (A53316)
BL331A-80 Air...
2008 Chevrolet Impala LT Sedan (A55853)
2008 Chevrolet...
Manac Walking Floor Trailer (A50322)
Manac Walking...
Pair of Red Cedar Wood Rocking Chairs (A55758)
Pair of Red Cedar...
