Replacing axles - brakes on both or one?
   / Replacing axles - brakes on both or one?
I've stopped too quick on occasion but wasn't because of trailer brakes
   / Replacing axles - brakes on both or one? #12
If electric brakes is what you are going to then do brakes on all axles
   / Replacing axles - brakes on both or one? #13
I have smaller utility trailer 5'x 8' wood floor, can haul 1600 pounds. Bought it for supply runs for weekend home remodelling. Been a fantastic addition, good size and capacity instead of hauling larger trailer with pickup. Which leads me into my question, is it possible to add electric brakes to a smaller axle? I pull with a Subaru Forester, on third set of brakes. Brakes on the trailer would help with control and cost of brakes on the car every year.
My old 1992 Doolittle 16' trailer only had one axle braked, added brakes to the other extremely easy and worth every penny, much safer to use after that. My brother in law borrowed last year and both axles folded up like a cheap camera. This year was the year to install two new Dexter 3500 lb axles and bring it back to life.
   / Replacing axles - brakes on both or one? #14
Look at the end of the axle just inboard from the wheel bearing, if it has a square plate with 4 holes to mount the brake backing plate you're good for adding brakes. Just matter of getting correct diameter for wheel size.
   / Replacing axles - brakes on both or one? #15
Can't have enough Brakes!
   / Replacing axles - brakes on both or one? #16
My experience is that surge brake failures are often caused by crappy master cylinders. If someone made a master cylinder that didn't rust, it would be great.
I believe these might be a good possibility for surge/disk brakes. But I have no experience with them.
Tie Down 1" Trailer Disc Brake Kit | Overton's
In your case, electric will be a good way to go.
   / Replacing axles - brakes on both or one? #17
Yes I agree brakes should be on both axles with that weight.
thanks for the replies, now I just have to find the time to do the work
   / Replacing axles - brakes on both or one? #20
Well how are the brakes working since their on both axles ?
Great! Will put you through windshield. Didnt realize just how depleted the old brakes were, and using trailer in that condition was dangerous and unsafe. Run controller around 2 to 3 on Doolittle trailer, and 4 to 4 1/2 on my dump trailer with 3 1/2 tons of stone dust.
2017 Ford F-150 Pickup Truck (A54814)
2017 Ford F-150...
2016 F-250 4X4 (A56435)
2016 F-250 4X4...
Mini Skid-Steer Steel Mounting Plate (New/Unused) (A59225)
Mini Skid-Steer...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58216)
GRID SHAPED BUCKET...
(9) ROLLS OF 5' - 10 GAUGE CONCRETE WIRE (A54757)
(9) ROLLS OF 5' -...
1995 ADVA Concrete Mixer TRUCK (A56858)
1995 ADVA Concrete...
