Replacing B2920 seat with a suspension seat
   / Replacing B2920 seat with a suspension seat #1
Denm99
Wabash
B2920HST
Has anyone replaced their stock seat with a suspension seat. When running rotary cutter on pasture I get bounced around all over the place so I wanted to change my seat to something that would make for a more comfortable ride. Thanks for the help.
   / Replacing B2920 seat with a suspension seat #2
Not on that machine. The job is doable without major fab work. At worst you have to make your own adapter plate, at best you find a seat base that bolts on directly to your machine. I put a grammar seat base on my zero turn and I'm happy I did it. If it wasn't so expensive I'd put one on my tractor too.
   / Replacing B2920 seat with a suspension seat #3
As noted, should not be hard but you'll have to fab up the mounting base or adapter or perhaps repurpose the mounting from the existing seat (which isn't much more than a hinge with springs).
I had a 2920 and it was a good little tractor, and a hot rod with all that HP.
   / Replacing B2920 seat with a suspension seat #4
I bought a Grammar suspension seat from Seat warehouse a couple of years ago, cost was about $160. It was a big improvement over the crappy seat that my LS came with.
Shortly after that, I just bought the suspension platform for my zero turn, as I like the factory seat quite a bit, it was comfortable, but rode a bit rough.
Both needed a couple of extra holes drilled, but were easy to install, and the end result was well worth the trouble. A note of caution on the seat though, if you weigh more than about 240, You may want to upgrade to a heavier duty suspension seat.
   / Replacing B2920 seat with a suspension seat #5
Yes, I would also suggest reusing the current seat and installing one of these, as long as you can live with it's 8 inch height and $300 price tag:
   / Replacing B2920 seat with a suspension seat #6
I've looked at the suspension seats and adapters but the problem for me is that they put the seat up much higher. I feel more comfortable sitting low rather than like a sitting duck. :)
The added height is what I was worried about. Thought maybe someone had found a seat or way to mount that would avoid that. Thanks for the advice.
   / Replacing B2920 seat with a suspension seat #8
I just took a measurements from my F3060, and if the factory seat suspension & back/forth slide adjustment was removed this suspension would elevate the factory seat by 2 inches.
I could probably live with that and not be able to adjust back/forth. The tilt steering helps.
30pc 3ft. x 8ft. Red Polycarbonate panels (A55758)
30pc 3ft. x 8ft...
1R CULTIVATOR, 3PT (A58374)
1R CULTIVATOR, 3PT...
2014 Toro Groundsmaster 4500D 5- Deck 4WD Rotary Commercial Mower (A56857)
2014 Toro...
TANK MANIFOLD (A55745)
2025 40ft. High Cube Shipping Container w/ 1 End Door & 4 Side Doors (Est. Retail Value ($12,000)... (A59225)
2025 40ft. High...
LOT: Welding Accessories: (2) Auto Darkening Helmets, Welding Rods, Welding Wire, Magnetic Arrows (A59076)
LOT: Welding...
