Mowing Replacing Bearings in Ford 908 Rotary Cutter
   / Replacing Bearings in Ford 908 Rotary Cutter #1
Beamer63
Altoona, IA
Ford 2000 1969
I have a Ford 908 Rotary Cutter that squeals when rotating. I am thinking bearings so I took the gear box off and took it apart. The bearings that I can see look good but there is one in the shaft just after the slip clutch that I cannot see and it seems to growl when I rotate it. The big question is does anybody have some good advice on how to get the bearings out of this thing? There are apparently some snap rings in line. I am wondering if they have to come off first before I can force the bearings out. The following link is a cut away of the unit. Thanks in advance for any help as I am somewhat mechanically challenged when it comes to this proceedure.
New Holland 22-195 FORD FRAME A. SERIES 908 ROTARY CUTTER
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2017 JCB 510.56 10,000lb 4x4 Rough Terrain Telehandler (A55851)
2017 JCB 510.56...
2017 Ford Expedition SUV (A55853)
2017 Ford...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A57024)
2016 KBH...
2015 FREIGHTLINER CASCADIA (A53843)
2015 FREIGHTLINER...
