Replacing bolts - which grade?
   / Replacing bolts - which grade? #1
Ford850
Super Member
Ohio
Case DX55, Ford 850
When rebuilding an old cultivator, or any old attachment for that matter, which grade is typically used for the general frame hardware bolts? I am working on an old Dearborn cultivator and I'm replacing most of the bolts due to rust as I make adjustments to it. I'm not refurbishing it, but getting it back into working order as a rusty old tool. These are bolts that hold bracing, the arms that hold the springs, and miscellaneous frame parts together. I've used a little bit of each grade during past projects but figured there must be a "right answer". The old bolts are too rusted to see any markings. So what's the best grade to use for holding an implement together but not subjected to extreme forces? Grade 2, 5, or 8?
   / Replacing bolts - which grade? #2
Use grade five NFT with blue "Loctite" no worries.
   / Replacing bolts - which grade? #3
Grade 5 or Grade 8 will work just fine.
I typically use Grade 8 because that is what I have the most of laying around. So If you have some grade 8's, dont feel like you have to run out and buy the gr5's, because 8's will work just as good.
But if you are short on bolts and HAVE to buy anyway, 5's will be cheaper:thumbsup:
Thanks for the feedback. I usually buy mine by the lb at TSC. Is there a better source?
   / Replacing bolts - which grade? #5
Thats the best that I have found:thumbsup:
   / Replacing bolts - which grade? #6
My two cents. Grade five. Best of both worlds. Not as soft as a grade two shear bolt, but not as fragile as a grade eight bolt. A grade eight won't stretch that much, and a grade two will stretch forever. There are Engineering terms for this, But I'm too lazy too look them up.
1981 LUFKIN 41 FLATBED (A55745)
1981 LUFKIN 41...
Swict 66" Bucket (A53316)
Swict 66" Bucket...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
UNUSED Hydraulic Thumb Attachment (A47477)
UNUSED Hydraulic...
Giyi Pallet Forks (A53316)
Giyi Pallet Forks...
