Replacing FEL Hose
/ Replacing FEL Hose #1
hobie
Massachusetts
Jazee One
I have an ancient B6000 that sprung a leak in a FEL hose when I picked it up. I got one end of the hose off easily with a 9/16 open end wrench, but the other end attaches to a metal hydraulic line, and the tube bends when I try to loosen the fitting. Any tricks as to how to get this off without causing more damage? Considering buying some big "C" clamps to attach boards to FEL to hold tube in place. Thanks in advance!
/ Replacing FEL Hose #2
The metal line should have a fitting for a wrench just like the hose. Hold one, turn the other.
/ Replacing FEL Hose #3
Use 2 wrenches like DT86 said...
BTW save yourself some problems and use "Line Wrenches" when working on lines...
If you know how to measure hydraulic lines and can identify the sizes of the ends, you can replace All the lines on your loader for the cost of 1 line at your local dealer.
/ Replacing FEL Hose #4
Always try to back up the other side with a wrench. Use line wrench when you can. You most likely will not be able to get a line wrench on the hose side, but you will be able to on the tube side. Good luck. Philip.
(2) BUNDLE OF MISC SIZE USED TIN UP TO 25' LONG (A62131)
(2) BUNDLE OF MISC...
8086 (A61165)
8086 (A61165)
Four (4) R207782 John Deere Wheel Weights (A63116)
Four (4) R207782...
2019 KOMATSU D61PXI-24 CRAWLER DOZER (A62129)
2019 KOMATSU...
PORTABLE SAND BLASTER (A62131)
PORTABLE SAND...
2018 Chevrolet Trax SUV (A59231)
2018 Chevrolet...
