Replacing fogged double pane glass
   / Replacing fogged double pane glass #11
Paddy, the glass is normally set in a chalk or glue to seal it in the sash. If you try some heat from a heat gun it will make it much easier to remove the glass. Might work with the plastic trim also depending on how it is applied.
MarkV
   / Replacing fogged double pane glass #12
i've got the same thing with General Windows: they started failing just after the warranty was out..i plan on looking into the life time guaranteed windows from home depot. years ago, the first window i had this problem with, i took it apart, separated the glass, cleaned and resealed it, plus put a penny between the glass: well, it fogged up within a couple weeks: back then i didn't know they had argon inside..if you do a little reading about how much you save in energy with double glass windows: it ain't that much..especially if you have to change one or two every year.
heehaw
Heehaw,
Windows account for about 28% of your heat loss. If folks wanted to realy save energy, they could use some sort of insulated shutter closed at night. You are corect, the R-value for double pane is still very low conpared to any other area of the home.
   / Replacing fogged double pane glass #14
a single pane window with a good storm attached is by far the best route to go, unless you get windows that have a life time guarantee. the main thing is air leakage: if its a quality window frame and storm window so they don't leak air, they will work great and cost you much less to maintain. i would never buy windows from General Window again: i have triple track windows, i didn't know when i got-em, they can't be disassembled, and they leak really bad.
heehaw
   / Replacing fogged double pane glass #15
HI,
My uncle IS a building contractor in NEWHAMPSHIRE,and in the early 90s he took out 6- 1 year old sliding 4by 4 windows out of a house.The owner was afraid his children could open them and they would fall from the second floor so he replaced them.They were like brand new and he gave them to me for this house.2years went by and every one of them failed.I hired a local glass company to change them,[of course a slider comes right out,so i took them to their shop one by one.]Its been over 15 years now and they are still great.The only thing i dont like is that the frames are aluminuim and they frost up in severe cold.So my answer to fix them or not,is Will your frames hold up for say 20 more years?
ALAN
   / Replacing fogged double pane glass #16
Several years ago we purchased a house with a clause in the contract that specified the owner would replace the roof and if the roof was not replaced by closing the owner would rebate the cost of the roofing job to us.
Consider a similar contract with a buyer and then let the buyer choose their favorite window.
   / Replacing fogged double pane glass #17
look at having a piece of glass, slightly larger than the window, put in a frame and mount it inside, over the window: that will stop the frost and stop any air leakage that might be there: then remove the glass in the spring.
heehaw
I would consider that except they look so bad it might give a overall bad impression. Some people the thought of having to do remodling after buying is a deal breaker. My roof is 22 years old. It looks fine and will likely have another 10 years with out issues. But, any potential buyer will say, "22 years...It needs a new roof!". Carpet and paint are good items to let the new owner pick out.
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A52705)
2017 CASE IH 580...
Flatbed Trailer (A51694)
Flatbed Trailer...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2015 Ford F-150 (A53422)
2015 Ford F-150...
